Direct Mode does not delete thumbnails for files deleted in Plex
Infuse in direct mode on Apple TV 4K - If a file is deleted in Plex it still shows on my screen in Infuse. Just wanted to check that this is expcted behaviour in direct mode. Refreshing or rescaning does not remove the file. Even closing the Infuse app and then opening it again does not remove the file. When you try to play the file it gives an error message that the file was removed or deleted, which is correct. I have to manually delete the file (thumbnail) from Infuse
