In recent infuse versions, there seems to be three options in the cache streaming setting:
Auto - Memory Only - Legacy
I did some search, and it seems Legacy means only memory will be used, as explained in this post (Cache streaming settings).
I was wondering what does Memory Only means, and if there’s any differences between this and Legacy.
Thank you.
See the answer in this thread: What does "Ultra-optimized streaming cache" in 7.3.7 mean? - #8 by james
Thanks for the reply, I’ll use Memory Only then.
