Desktop not showing correct next up
On my Apple TV+ When i have watched an episode of a TV programe the next up does not always update or sometimes goes back to 1. Also, is there a way to remove entries on the desktop for old episodes that are further back, if I go into the entry and mark it as watched, so a tick appears, it still remains there.
Does anyone have any ideas please or do you need more information
Are you seeing this behavior in Infuse or the Apple TV+ app?
Infuse will auto-select the first unfinished episode in a season and present details for that in the top row (Up Next List). If you are further along in the season you can mark the earlier episodes as watched and Infuse should then present the correct episode.
If you want to remove a series from the Up Next List you can long-press on it and select the ‘Remove from Watching’ option.
Sorry you’re having problems, just to clarify a bit,
you’re talking about the Apple TV 4K or HD device correct? Or are you talking about the Apple TV+ subscription service?
Assuming your taking about Infuse on the ATV4K or HD,
If you’re talking about the row of watching tv shows on the top of the Infuse home screen you can long press on the item and select “Remove from Watching”
If by “tick” you mean the orange corner tab when it’s there it means the video is unwatched. When it’s gone it means you’ve watched it.
In this example, region 1 is unwatched and region 2 is watched.
I agree that Infuse should auto select the next unfinished episode, but sometimes that does not happen for some strange reason and just keeps showing the same episode, do you have any idea why.
I am talking about Infuse on an Apple TV 4K.
When trying to remove an item on the top of the Infuse home screen I tried your suggestion and and did a long press on the item but REMOVE FROM WATCHING WAS NOT ON THE LIST
Regarding the tick on the left of the view, the first picture below shows the EYE icon when the item has not been played,
and the second picture shows the tick
It looks like you long pressed on a “Recently added” item not a Watching item.
Ahh I didn’t notice that, i suppose that they cannot be removed or should just be ignored
You can turn off recently added in the up next list in settings. I did this since I wanted just the shows I was watching at the top of the home screen.
Settings > General > Up Next List
Thanks for that, thats realy helpfull advice
