In ios 18 DB3 (latest at the present), delete button is absent.
This issue is there in AppStore version of infuse.
PS: I am using mega.
Sounds like you have File Management turned off in settings. The Delete menu is visible for me in both store and beta versions. I’m also running 18 DB3.
Ohh. Thank you. That solved it. I guess it must have been turned off by mistake or on update/reinstall.
