DeInterlace 480i
I just upgraded to Infuse Pro after using Infuse for a while.
I record Over-The-Air sub-channel programming which is usually broadcast in 480i, (using TVHeadend on a Raspberry Pi.)
When watching on an iPad with Infuse, the interlacing is clearly visible, particularly in areas with objects in motion. When watching the same recording using Kodi on a Raspberry Pi, there are options for deinterlacing which work well and the Raspberry Pi seems to be able to do it without breaking a sweat. I’m hoping that it is possible to add similar deinterlacing to Infuse.
