Defaulting to Commentary Track
Hello, since yesterday’s update (6.04) if there is a commentary track on a movie or TV episode Infuse is defaulting to it instead of the regular audio track.
Can you try changing the audio language option found in Settings from Auto to your desired language, and see if this helps?
Thanks for the reply, James.
I originally had it set to English, but switching it to auto seems to have solved it.
Great!
For a bit of background, having it set to Auto will allow Infuse to honor the ‘default’ tag if it’s set for one of the audio tracks.
Thanks for the additional information. That’s helpful to know.
