The audio offset function is great when dealing with the Apple TV and ARC. I find it isn’t consistent so sometimes I’m moving from no offset to -100 offset to +100 offset as I switch between different content.
Would it be possible to have a couple of default options in the Audio pull down menu? So I could switch to -100 or +100 without pausing the playback and moving the offset amount up and down? Ideally these would be adjustable in settings for different users. I’d like to be able to select offset on/off, default 1 and default 2 from the pull-down audio menu with a 4th option to go into the delay page for finer control (as now). Changing the delay would be like switching audio track or subtitle.
