Debug logging menu / More Info on error messages
Sometimes it would be extremely useful to be able to see more information about an error message that pops up when trying to do things like connect to a network share from the ATV2 with Infuse. Something like a "More Info" button on the error dialog, which opens another dialog that has a more technically detailed error message. The technically-bent could use this information to try to fix the problem.
Alternately (or better yet, in addition), it would be quite handy to have a Debugging menu option - select this, then select the program area and/or level of detail you want to see. Then try to perform a function that you're getting an error from, get the error, and go back to the Debugging menu where you can view the log file telling you exactly what happened.
