Cydia Upgrade?
Should I be upgrading cydia on my ATV2? Every time I run apt-get upgrade it tells me:
The following packages have been kept back:
  • apt7-lib cydia
When I run "apt-get dist-upgrade -V" it shows that I'm running cydia 1.0.3222-73 still...
The following packages will be REMOVED:
  •    apt7-ssl (0.7.25.3-3)
  •    bigboss (0-13)
  •    cydia-sources (0-11)
  •    modmyifone (0-5)
  •    zodttd (0-4)
The following NEW packages will be installed:
  •    cydia-lproj (1.1.12)
  •    debianutils (3.3.3ubuntu1-1p)
  •    org.thebigboss.repo.icons (1.0)
The following packages will be upgraded:
  •    apt7-lib (0.7.25.3-11 => 0.7.25.3-13)
  •    cydia (1.0.3222-73 => 1.1.12)
Searched online and through the forums for a bit but couldn't find any best practices or recommendations...
Thanks!
bump?
I didn't kow there was a cydia app.
OK I had the same issue and decided to try upgrading - it worked OK! no issues after reboot, so looks like it’s safe. Not sure what has changed though :slight_smile:
Apple-TV:~ root# apt-get dist-upgrade -V
Reading package lists… Done
Building dependency tree
Reading state information… Done
Calculating upgrade… Done
bigboss (0-13)
modmyifone (0-5)
zodttd (0-4)
cydia (1.0.3222-73 => 1.1.16)
2 upgraded, 3 newly installed, 5 to remove and 0 not upgraded.
Need to get 1394kB of archives.
After this operation, 2765kB of additional disk space will be used.
Do you want to continue [Y/n]? y
Get:1 http://apt.saurik.com tangelo-3.7/main cydia-lproj 1.1.12 [66.9kB]
Get:2 http://apt.saurik.com tangelo-3.7/main debianutils 3.3.3ubuntu1-1p [6164B]
Get:3 http://apt.saurik.com tangelo-3.7/main org.thebigboss.repo.icons 1.0 [11.5kB]
Get:4 http://apt.saurik.com tangelo-3.7/main cydia 1.1.16 [845kB]
Get:5 http://apt.saurik.com tangelo-3.7/main apt7-lib 0.7.25.3-13 [465kB]
Fetched 1394kB in 6s (217kB/s)
(Reading database … 7462 files and directories currently installed.)
Removing apt7-ssl …
Removing cydia-sources …
Removing bigboss …
Removing modmyifone …
Removing zodttd …
Selecting previously deselected package cydia-lproj.
(Reading database … 7429 files and directories currently installed.)
Unpacking cydia-lproj (from …/cydia-lproj_1.1.12_iphoneos-arm.deb) …
Replacing files in old package cydia …
Setting up cydia-lproj (1.1.12) …
Selecting previously deselected package debianutils.
(Reading database … 7492 files and directories currently installed.)
Unpacking debianutils (from …/debianutils_3.3.3ubuntu1-1p_iphoneos-arm.deb) …
Setting up debianutils (3.3.3ubuntu1-1p) …
Selecting previously deselected package org.thebigboss.repo.icons.
(Reading database … 7493 files and directories currently installed.)
Unpacking org.thebigboss.repo.icons (from …/org.thebigboss.repo.icons_1.0_iphoneos-arm.deb) …
Setting up org.thebigboss.repo.icons (1.0) …
(Reading database … 7498 files and directories currently installed.)
Preparing to replace cydia 1.0.3222-73 (using …/cydia_1.1.16_iphoneos-arm.deb) …
Unpacking replacement cydia …
Replacing files in old package saurik …
Setting up cydia (1.1.16) …
(Reading database … 7507 files and directories currently installed.)
Preparing to replace apt7-lib 0.7.25.3-11 (using …/apt7-lib_0.7.25.3-13_iphoneos-arm.deb) …
Unpacking replacement apt7-lib …
Setting up apt7-lib (0.7.25.3-13) …
Apple-TV:~ root#
Apple-TV:~ root#
Apple-TV:~ root#
Apple-TV:~ root# reboot
