Cyberduck not working.
Since I use aTVflash cyberduck won’t connect to my AppleTV
(I have used a different hack before I bought aTVflash).
Do you have a tip on how to enable cyberduck for use with my AppleTV ?
(I don’t like fugu , it’s full of bugs and slow compared to cyberduck, with cyberduck I transferred files to the AppleTV
5mb/sec - the max speed I have with fugu is about 1.8mb/sec. )
Also with aTVflash : random reboots , no DVD playback at all.
Fix for all your problems is coming in the new version that should be released today. Cyberduck will be supported, with MUCH faster transfer speeds than before.
Thanks for reply.
Have I missed something or is the update ‘delayed’ (your reply was on 30-06, it is now 03-07)
[quote=““k-the-ripper””]
Thanks for reply.
Have I missed something or is the update ‘delayed’ (your reply was on 30-06, it is now 03-07)[/quote]
Yes, you are correct. We have an announcement a the link below. 7/8 is the new date.
