Hi all
does anyone know if you have a usb hard drive attched to the apple tv can you use Cyber duck to store stuff to it or do you have to remove it and attach to a computer
Many thanks
Chris
Hi all
Many thanks
Chris
Yes, when connected the drive will be visible inside the ‘Movies’ folder when connected via FTP.
