Customized Artwork GONE
What the heck happened. I spent days downloading all the cover art for movies, tv shows, even tv seasons. I put all the artwork in the folder and called it “Folder.jpg.” It worked great. My libraries didn’t change and the ATV didn’t have to waste time searching and downloading covers. Suddenly with 7 that functionality no longer works. Are you planning on fixing this. I’ve counted about two dozen covers so that aren’t even in English. Please fix this.
Isn’t folder.jpg only used when browsing Files but not using the library?
If you are using the library you need to follow this guide:
At main screen, select the favorite you want, long press and hold ATVs touch button and select “Use Local Metadata”. Please come back with feedback, we’ll make it work dude, dont worry :slight_smile:
