I use Kometa to build collections for my items in Plex, they are sorted by the source of the collection (Trakt in my case). In the Plex app these items are sorted in the order they were set in, however in Infuse it appears to be by name or release date of the film, is there any way i can do this?
Are you browsing these the Plex server directly or using the Library features in Infuse.
Infuse’s Library features will have limited options for sorting order of Collections, but browsing the Plex server directly should allow you to see the sort order from the server. You can also change the sort order on the fly while browsing directly.
So I did it through the Library feature; doing it through the Plex server appears to work but then I can’t pick that collection to my Home Screen which is ultimately what I’m trying to do. I want to show my “Trending” collection on my Home Screen.
I can confirm in the new Infuse 8 this works as desired with library feature disabled
