Updated to 8.1 just now and it’s deleted my Library icon artwork from the favourites list. Trying to re-select the artwork doesn’t help.
Same but only one of them is not working for me, the other custom icons remained.
Are you using the long press on the favorite to try and select it again?
Maybe a restart on the ATV just to clear the update cobwebs?
Which one is missing the artwork?
The Library one, but if I go to edit it, it shows the correct one. I’ve also tried to reset the icon for it and reselect it to no avail.
Restart doesn’t solve this either, and the issue is on multiple ATVs for me so far.
The same is happening to me.
Thanks for trying, often that solves a ton of problems. ![]()
Thanks for the reports.
We’re looking into this.
Exact same thing happening here. My personalized “Library” artwork no longer works. All the other - movies, tv shows, collections etc. work fine.
Having the exact same problem described by [UncleBabyBilly] regarding the “Favorite” custom artwork, on all my ATVs since Infuse 8.1
Same case
A fix for this will be included in Infuse 8.1.1 which was submitted to Apple today.
Thanks for your patience. ![]()
Just logged on to report this as well. I will wait for 8.1.1 to be released. Should be very soon ![]()
This has been resolved in today’s 8.1.1 update.
WFM - thanks.
