Custom fanart/tiles
I used to have custom made tiles to categorize my Movies.
But when i integrate Plex with Infuse im not able to select those tiles.
They just dont appear in the maps Where they used to work fine.
Bet there’s a solution for this:)
Anyone?
Custom artwork is added a bit differently when streaming from Plex.
To add artwork, simply long-press on a Favorite and choose the ‘Select Artwork’ option.
Note: You won’t be able to access image files from Plex, so you may need to set up a (temporary) second share to get access to your images.
