CrystalHD BCM70015 installed but not recognised
Hi guys
Ima ll new to Apple TV. I bought a broadcom bcm70015 from a guy on ebay and installed it as per the youtube videos. now when i try to play, it does not get an internet connection. The guy told me i didnt need to install any software and it was basically plug in and play.
I have a jailbroken Apple TV 1 running XBMC and still contains the original apple software. How do i get the ATV to recognise the card and get it to work?
Kevin
anyone?
Have you looked over the guide for enabling the Crystal HD drivers?
A good step-by-step can be found here.
you can not get on the internet once you take out the wifi card you will have to plug into your router
