Crystal HD - keep losing with each start up.
I got Crystal HD card installed and working except one thing that I cannot get to work -
I have done the following:
Setup
1. Run the Smart Installer to complete installation.
2. Install Crystal HD through Maintenance --> Install Extras menu.
3. Load drivers through nitoTV --> Settings --> Utilities --> Kernel Extension Manager
  • Highlight 'BroadcomCrystalHD.kext' item and press center (play/pause) button. This will enable the driver until the AppleTV restarts.
  • For auto start, highlight the same item and press the right arrow (>>) button. Then choose the option to 'Add to rc.local'. This will ensure the driver loads automatically when the AppleTV restarts.
For some reason, I have to redo this step after I reboot my atv - I will have it working but then, even after adding to rc.local - it still is gone after each reboot.
It won’t show up in XBMC for instance until I reinstall the driver in Nito.  Then have to go to set it back up in xbmc each time.  Kind of a pain in the butt.
One odd thing - with the card, my fastforward is different in both media player and xbmc - much faster.  This DOES stay behind after the reboot…
Any suggestions would be appreciated.
