Hello from Germany
Crystal HD don’t work with 4.1.4. Why?
Only Factory Restore. Because ATV-Flash Update 4.1.4 don’t work (Black Screen) and Remove Remote HD App don’t work.
Factory Restore now finished - But now Crystal HD don’t work.
XBMX 9.11 Nightly Update the is only “Software” “GLS” and “ARB” and NO “BroadcomCrystalHD” like before (xbmc-r28256-trunk-x86.dmg) or up-to-date r31632. I change it with Cyberduck.
Than I follow this:
- Ensure you are running the latest XBMC/Boxee Launcher (update through Maintenance → Manage Plugins menu).
- Download the latest XBMC svn build through the XBMC/Boxee → Downloads menu.
- Download the Crystal HD drivers through Maintenance → Install Extras
- Run Smart Installer (if not already done)
- Navigate to nitoTV → Settings → Utilities → Kernel Extension Manager. Highlight the BroadcomCrystalHD.kext, press the right arrow and select ‘add to rc.local’.
- Restart the AppleTV, launch XBMC (xbmc-r28256-trunk-x86.dmg)and change the following settings in XBM under System → Video → Playback
a) → Render Method. Change “Auto” to “Broadcom Crystal HD”.
b) → Use Pixelbuffer Objects. Turn “on”.
c) → Adjust Display Refresh Rate to match Video. Turn “on”.
d) → SyncPlayback to Display. Turn “on”.
e) → A/V Sync Method: "Audio Clock"or “Drop Dupe” - Enjoy 1080p playback.
I would have only made no Upgrade.
Joerg
