Please enable Emby content to be added to Custom Collections. At the moment I can only add direct access content. I assume Plex and Jellyfin content would also need enabling.
Hopefully when built this will allow a mix of sources in the same collection.
I currently am a shared user of a Plex library that is not mine and have it connected to Infuse. There are a bunch of movies and TV shows on the server that I don’t care about.
It doesn’t seem possible to add Plex movies/shows to a custom collection for some reason. Is there another way to add shows and movies to a collection or “favorites” so I can add only the shows/movies I care about?
Basically, I’m looking to create something similar to the Watchlist feature on Plex. I tried using Playlists which is close, but it adds each TV show episode separately which isn’t what I want.
I moved your post to a currently running thread requesting this feature.
Don’t forget that you need to click the like button on the first post in this thread to show your support for this suggestion!
