Once a network (NAS) share has been created, it seems to force the user to browse from the root of the share.
Is it possible to create a link from the "home" screen that would go to a specific directory within the share? Or to configure a share to only expose a particular directory?
Thanks, and great work!
[/quote]
When you are setting up a share entry, you can include directory information at the end. For instance I have a entry with a display name of FILMS that is set as path-to-share/FILMS, and another called TV set up with path-to-share/TV.
[/quote]
Thanks, itimpi. Where should the path value get set? I tried it just after the name like this:
[/quote]
Sharename /path/to/files
but this didn't work.
The address field seems to be not editable.
TIA!
[/quote]
You will actually need to select the 'Other...' option to setup a share manually. Then you can enter the address with the folder path of your choice.
Also, we're working on a dedicated option for setting up favorites for an upcoming version. :)
