Hi
I’ve just downgraded my firmware to 4.3 (to run xvmc better) using seasonpass and have installed atv flash black 2.02. Everything seems to be working as normal except that when i try and access the settings menu under maintenance it instantly crashes the atv. I wouldn’t mind except that is where i can back up my setting so would like to be able to get in there. I would also ideally not want to have to re jailbreak as it took me a long time to get it to downgrade successfully. Was wondering if maybe i need an older version of atv flash? Any ideas?
Pete
