Cover art size ratio not fit issue
I have plenty of movies with its own metadata file (.info format). Its poster art and cover art are also included. The new UI design are so beautiful. But I found an issue in the movie detail page. My cover art are 16:9 ratio, but the new UI just crop the picture to fit. In most of movie, it is ok, but if infuse give an option for us to display the full size cover art, it would be better. Or you can give a much better solution to fix it.
Can you post a screenshot of what you are seeing?
In general, Infuse works best with poster art in 2:3 ratio and fan art in 16:9.
Both the fan art of the movie and the anime are cropped on iPhone. It looks good on my iPad and MacBook.
发自Dadachen的iPhone
