Cover art issues
I’ve been having issues with cover art for some TV shows. Is there a way to fix this?
Infuse PRO is at version 7.4.7 (4283)
Can you provide a server screen cap of the folder directory with file names you have for the series giving you problems?
Does the cover art appear correctly if you browse these shows through Library > TV shows?
Using the Library will usually provide a better experience compared to browsing via folders.
