does the latest atvflash update -4.0.1 for the 3.0.1 apple update support the couch surfer application?
It didn’t for me
that"s a bumber…hope they can fix this soon…
I just installed for me last night. it didn’t work. neither did the Macromedia Flash installation.
A 3.0+ compatible version of Couch Surfer should be available in the next 1-2 weeks.
FYI
Does this update support couch surfer?
No - it doesn’t
I am among those with ATVFlash 4.0.2 and AppleTV 3.0.1 (per the installation instructions). Couch surfer doesn’t appear as an option and the entire NitoTV is buggy. I am terribly disappointed so far as the entire reason for purchasing software that bundled FREE applications was to avoid the hassle of setting it up yourself. I am hoping these issues get resolved soon …
Many of the frameworks that Couch Surfer relied upon were changed in the 3.x AppleTV software. This required almost and entire rework of the inner workings which has taken some time. Couch Surfer Pro is nearly complete, and should be available within 10 days.
Once available it can be installed via the Maintenance > Manage Plugins menu.
If you’re having any other issues, please send a direct email here: http://www.atvflash.com/contact.php
Couch Surfer Pro is now available for the 3.x AppleTV software.
The current version can be downloaded and installed directly on the AppleTV through the Maintenance > Manage Plugins menu.
Hello, I am trying to hulu to work thru couch surfer.
Do these flash install instructions still apply. I was confused because of references to Tiger (vs Snow Leopard, etc.).
