Hello all,
I recently brought my trusty old ATV2 out of retirement, when we installed a new tv in the guestroom.
It’s running ATV Flash (black) 2.4, on 5.3 (6105).
I had never installed Couch Surfer Pro, and figured I’d give it a go.
2 questions:
1.) Does CSP still work as advertised? Will I be able to browse the net on my ATV2 - preferably to stream some Youtube videos etc?
If no >> then I needn’t go any further.
2.) Upon attempting the installation, was met with the following error:
E: dpkg was interrupted, you must manually run dpkg --configure -a
to correct the problem
I googled the above, and came across several hits dealing with XMBC/Kodi.
Assuming I can work out how to use Terminal to SSH(?) into my ATV2 - do I literally just ‘run’ the command line as above, or is it a bit more complex than it appears?
Would be ever so grateful for any assistance!
