Couch Surfer Pro bookmarks issue
Hello everyone!
I’m on latest ATV Flash (Black) 1.3 and I’m having troubles deleting a bookmark from Couch Surfer Pro.
Two bookmarks are correctly working, one is blank and when I try to open it I get this message :“Bad URL Press menu to go back to main menu”.
Deletion process seems to work, but the bad bookmark keeps to stay there.
I tried to connect via SFTP to remove the bookmark manually but I can’t find a Couch Surfer Pro bookmark file or folder.
Any suggestion?
Best
giagio
Solved :slight_smile:
The file is under User/Library/Preferences/CouchSurfer/Bookmarks.plist
Once there you can add and edit all the bookmarks you want easily. You can also change the display name shown on Apple TV.
Best
giagio
