Couch Surfer only option on menu now! HELP
I don’t know what happened or how to solve it.
I have the 3.5 aTV installed. I went to “software” on the menu and looked at updates that were apparently available for programs. I saw that Couch Surfer said it had an update so I ran it. After Apple TV “rebooted” the ONLY thing on my menu is Couch surfer and its sub-menus. ALL OTHER FUNCTIONS are gone. I tried a Factory Restore of Apple TV only to get to the same place. This is BAD any help would be much appreciated.
Ok. It looks like I was able to do a factory restore. Still not sure what happened though.
It’s possible that somehow the Finder plugins got moved. Let us know if it happens again, even though I think you are in the clear now.
