Correct way of tagging
Hello, everyone. I was wondering if there is a correct way to name the files. For instance, if you are using plex naming the files following this way of naming movie (or whatever) {ttimdbtag} or {tmdbtag}.mkv the indexation will ignore all before the braces and the identification will be directly based on the braces tag. I don’t know if there is something similar here. Would be useful to have it and force it with no need to use a custom .nfo.
Take a look at this article for filename matching
Infuse doesn’t currently support a way of directing which source to use for metadata but the link that @munpip214 has above will give you a good reference on what Infuse looks for.
But if you are using plex then infuse will take whatever metadata plex is using
