Correct audio track for playing MKV?
I have a MKV with two audio tracks. One is AAC stereo and the other Dolby 5.1.
Airplaying the MKV to my AppleTV with the stereo track works good. When I select the Dolby 5.1 audio track however, the video stutters and won’t play.
Is there a specific requirement for audio tracks to play correctly?
I have found the solution for my problem, and it wasn’t a problem in Infuse.
Today, I discovered that the Dolby Digital setting on my Apple TV was set to “off”. I switched it to on, and everything is working fine :slight_smile:
I am a bit embarrassed that I overlooked such a simple solution…
Ah, that would defintely do it.
Thanks for circling back and posting your fix. :slight_smile:
