Controlling Collections
Looked but didn’t see anything on collections other than turning on or off. Do you have any control on name conventions, etc? Ex. Have a bunch of Godzilla movies. It puts them in several folders by directer. That’s ok but creates a folder called American Godzilla. Now I have to remember to look in the “A” when all the rest are in folders next to each other. Thanks for any pointers.
You could create a “Playlist” of these and have them in the Library and/or on the home screen too.
Also, if you prefer to avoid Collection grouping while viewing All Movies you can disable the Collections option in Infuse > Settings.
Collections would still be available while browsing the dedicated Collections section in Library > Movies.
