When using my iPhone or iPad… with continuous playback turned ON… if I pause any item and the device eventually locks… and I then unlock the device and try to continue playing… playback fails and infuse jumps to the next item. If I then manually go back to the previous item, it starts from the beginning.
This happens basically all the time, as long as continuous playback is on. It’s never happened with continuous playback turned off. This has been the case through various versions for the couple years I’ve been using infuse.
Kind of annoying. Any thoughts?
