Content with DV and HDR10+ metadata played as HDR10
I have a few movies/TV series episodes that got DV and HDR10+ and Infuse on my ATV 4k 3rd gen 2022 plays them as simple HDR10 on my Samsung TV while the Plex TV internal app plays them correctly in HDR10+. Is there anything I can do to help you guys fix this problem?
Mediainfo:
Video
Formato : HEVC
Formato/Informazioni : High Efficiency Video Coding
Profilo formato : Main 10@L5@High
Formato HDR : Dolby Vision, Version 1.0, dvhe.08.07, BL+RPU, HDR10 compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
ID codec : V_MPEGH/ISO/HEVC
Durata : 58min 5s
Bitrate : 24,4 Mbps
Larghezza : 3.840 pixel
Altezza : 2.160 pixel
Rapporto aspetto visualizzazione : 16:9
ModalitĂ  frame rate : Costante
Frequenza fotogrammi : 23,976 fps
Spazio colore : YUV
Sottocampionamento croma : 4:2:0 (Type 2)
ProfonditĂ  bit : 10 bit
Bit/(pixel*frame) : 0.123
Dimensione traccia : 9,90 GiB (94%)
Default : Si
Forced : No
Intervallo colore : Limited
Colori primari : BT.2020
Caratteristiche trasferimento : PQ
Coefficienti matrici : BT.2020 non-constant
Colori primari display mastering : Display P3
Luminanza display mastering : min: 0.0050 cd/m2, max: 1000 cd/m2
Livello luce contenuto max : 1169 cd/m2
Livello luce media fotogramma max : 446 cd/m2
Infuse is likely defaulting to DV, which if your Samsung does not support, will cause Infuse to fall back to standard HDR10.
If you disable DV, it might grab the HDR10+ instead?
Do you mean I should pull the DV metadata off the file?
You can perhaps try going to settings in Infuse.
There should be a setting for Dolby Vision.
See if it makes a difference if you turn it to “OFF”
No difference, contents still get played in HDR10 and not in HDR10+. Thanks for your suggestion though.
By the way, it looks like yet another Apple TV issue as Samsung Apple TV+ app plays content in HDR10+ while the same app on Apple TV 4K 3rd gen does not.
