An error occurred
Failed to read the file with URL (Cannot open stream)
it happens so often and nothing is fixing it… I start the stream from any app and it gives this error, if I play it a second time it might work. How do I fix this?
what version numbers of Infuse (not just “the latest”)
version numbers of OS (not just “the latest”)
What you are streaming from (device and protocol like SMB, FTP, Plex, Emby etc.)
Just a quick thought, if you’re seeing the issue the first time and then the second time work then it sounds like something is sleeping and it takes a bit to wake. I’d try up to 4 times in a row and see if it works consistently. That would help narrow down what’s going on but without any more info it’s not possible to say.
