Consolidated Lists
The feature I have always wanted from a box like this is to have all the various sources compiled into one list.
For example with movies, it would be nice for there to be a single “Movies” option, and have it compile all of the available movies from iTunes, Netflix, Hulu, your media library, etc… into one list.  There could be little icons that tell you the source, and filters that you could use to filter out ones that cost, or ones that are local, etc…
