hello, I have a problem of connections to my mac. When I go on file sharing it does not propose to put a username and password but Infuse asks me one. could you help me please ?
There are a few things to check.
- SMB is enabled on your Mac (more info here Set up file sharing on Mac - Apple Support).
- At least one user is selected under ‘Windows File Sharing’ (as shown under ‘Advanced Options’ in the link above).
- Selected username and password are being entered in Infuse.
Note: iCloud username/password cannot be used. If you’re using an iCloud ID to log in to your Mac, you will need to set up a new ‘Sharing Only’ user as described here: https://support.apple.com/kb/PH18695
It’s works !!! Thank you very much
