Looking at the website, it implies you can use Infuse without a Pro license. I wanted to give things a try, see how I liked it. But the moment I try to play a video - any video - I’m taken to a screen where my only options are to upgrade to Infuse PRO. One of the selling points given is “Play more videos” - but I can’t play any videos! So surely that should be “Play videos?”
What exactly is the difference between the free and Pro version? Basic video playback is included in that difference?
The most common cause for requiring the pro features is that the video contains an AC3 or Dobly soundtrack which requires software that Firecore have to pay a license fee to Dolby (and therefore is not available in the free version).
Therefore I suspect this is the most likely reason Infuse won’t play your videos without the pro feature.
I am unable to play ANY videos, including ones that do not contain AC3 or Dolby soundtracks. Literally every video directs to the same subscription screen. Even ones with no sound track at all. Edit: I have a video library of ~20k items of numerous formats and cannot get Infuse to play a single one I’ve tried so far. Guess the non-Pro compatibility is severely limited.
Guess I’ll stick to Plex which plays them (without transcoding either video or audio track in all the ones I tested) just fine.
Infuse supports a wide-variety of codecs in the free version, but certain codecs do require a license and these will require Pro in order to play.
You can get a free month long trial of Infuse Pro by selecting the Yearly option, and as long as you cancel before the month is up you won’t be charged a cent.
Otherwise, if you want to test out Infuse without starting a trial you can download one of the versions of ‘Tears of Steel’ found at the link below, which should play in the free version just fine.
What’s nice about Infuse is you’ll be able to play all your videos just fine, without worry about needing to transcode. You really should give the free month a try.
