I’ve configured Infuse to access the library on my NAS (in LAN) using a regular fileshare. But is there a way of accessing my library remotely with only “one” library?
Currently I’ve configured the library “again” for a WebDAV connection that points to my NAS, that works but I only want one library instead of two if possible.
Hints?
Thanks in advance
This will give you the basics to get you started.
Not really, I’ve already a WebDAV in place.
Can you use the WebDAV for your local connection as well?
yes, VPN into your home network when you are remote.
various options available, Tailscale being one of them.
Yeah I guess VPN is one way, however I’d like something else, that Infuse could understand it’s using the same library but for several connections in some way. ![]()
Using WebDAV right now for both local+remote and it works but kind of feel slightly odd..
Why would you want another way with vpn does exactly what you want
I seems like you are purposely trying to make it harder for yourself
