Hello,
Compatibility with iOS app Remote (4.0) from Apple, when in folder view the Menu (to go back - or up a folder structure) does not register. You have to navigate up to the “Favourites/Shortcuts” bar, the menu button then works, but it takes you back to the AppleTV main menu, to then go back into Infuse, to then switch folder.
Hope that makes sense. Didn’t do this with 3.x Remote.
Thanks,
Lindsay
