Command not found
In terminal i get to step 7 in the tutorial which says:
“Now type the following command: sudo ./createPatchstick You will be prompted to type your password. This is your
user password for your Mac. Enter your password.”
I type the command, enter my password and then get: “sudo: ./createPatchstick: command not found”.
What to do?
Please download the latest 3.2 software. The install process has been simplified, and it has compatibility fixes for the latest Apple TV 2.1 software.
The download link will be in the My Account section of our site.
