I have two shares filled with 4k movies.I have added both and i can see them as two seperate favorites.Is there any way to combine both into a single favorite folder where i can view all the movies together.i tried renaming both with same name but still it shows as two favorites.
You can create a favorite for all of your 4K movies by going to Library > Movies > By Resolution > Then long press on “4K” and select “Add To Favorites”.
That will not only combine your two 4K movies folders but any other 4K movies you have in other folders will be included also.
Is this somehow possible through Plex? Big 4K-files plays much better attached to Plex.
Infuse can combine files stored on Plex or any other source.
More info on getting set up with the library can be found here.
