Color calibration controls and pattern generation
Not sure if this is possible. But what would make me and my customers happy would be options for white balance and possibly a six axis color management system, or even better the possibility to load 3dluts. Would be great if it would be possible to generate patterns from within infuse. But there are apps for pattern generation, but then the question is if infuse outputs the same as the generator.
