Collections sort
On the Mac infuse, collections has sort option by title or filename. On “title” Hunger games is sorted under “H”, I changed it to sort by filename and it is sorted under “T” , I assume because of the word “THE”.
My filenames do not start with the word “The”, just “Hunger Games”. Why is it sorting the collections by the word “The” when it’s suppose to sort by filename?
Am I missing something?
Run the file through MediaInfo and check the internal file name. Most likely it’s named with “The” in the file name internally.
If it’s a MKV file, MKVToolNix has a header editor that will remove the internal name.
