„Collections“ not showing all collections
Weirdly when going to library → collections only a very small number of all my collections (a mix of collections from Jellyfin in library mode & my Apple TV strmlnk library linked via SMB) are showing up.
What type of collections are you expecting to see that are missing?
When using Jellyfin in Library mode Infuse will pull collections as generated from the Jellyfin server instead of creating its own from TMDB.
Yeah, I’m expecting to see all the collections from the Jellyfin server (+some created by Infuse out of the Apple TV movies) but only a small proportion is actually showing up.
Same issue here. I have 50 collections in Jellyfin but only 17 appear in Library Collections. This persists across multiple devices with iCloud mode off.
Hi, I am also seeing the same issue using iOS app and MacOS app. My infuse is connected to my server via Emby. When I pin collections to the Home Screen I am only seeing the first 20 items from my library collection. However, if I go to Files - Emby to see all my libraries (Movies, TV Shows, Collections) and click on Collections I can see all 197 items in my library collections.
On a side note, when I first pin Collections to my Home Screen I can see all 197 items from my collections library. When I close Infuse and re-open that is when it then only shows the first 20 items. Seems it is not saving the info after being added then program closed and re-opened.
Hello,
I have the same issue. I tried removing the library and importing again, but my issue comes back. For me, it is the same number, only the 20 collections show up. If I reset it, the ones shown might change, but they are still 20 items no matter what.
I have jellyfin, I also see the collections if I access Jellyfin file folders directly. So I guess it is not unique to JF if it happens on Emby also. I could swear on an older version of(from a little more than a year ago) it showed all the collections no problem, but an update broke it.
Fingers croseed for a solution!
This seems to be a limitation with Infuse & how it handles collections. If pinned to the main page it will only show about 30 collections I think. The best way to view all is to go to your “Share” & favorite “Collections” , this will bring up a “collections” option on your main page listed under “Favorites”. Open that favorite & you will see all of your collections with sorting options in the top right corner
