Collection names replaced with Numbers on 7.4.1
All sorted for me too. Everything back to normal, and did not need to refresh metadata first (maybe it did it in the background automatically).
On a similar(ish) matter, do you guys plan to add the ability to add custom artwork to custom collections? At the moment it’s just a collection of artwork tiles taken from the titles in the collection, so it doesn’t look great.
Already running in the Suggestions forum here.
Don’t forget that you need to click the like button on the first post in that thread to show your support for this suggestion! :wink:
Still seeing the problem here.
Code: 6PDEE
Did you do this?
All set for me too, thanks!
Just did ‘Refresh Metadata’ again (I did it before posting for the first time) and I still see numbers for all the collections.
So you’re seeing numbers for ALL collections? Could you post a screen shot of this like @r0cksteadydrew did above?
Also, how big is your movie library?
Are all of your collections showing as numbers?
Are the numbers shown in your screen cap only collections since you’re in the “All Movies” library or are you seeing individual movies also as numbers?
Have you tried restarting the ATV and doing a refresh metadata?
  • As far as I can see, all collections are showing as numbers.
  • Individual movies are showing correctly with their normal titles. Also if I enter into a collection, I see the names of all of the collection movies correctly.
  • I tried restarting the ATV and doing a refresh metadata with the same result.
One other thought, on one of the collections that is showing numbers go into it and select each movie and do an edit metadata and re-select the correct movie. Do that for all of the movies in one of the collections and see if it may get that one collection back.
I just tried this suggestion and it worked for one collection, but not for the next one I tried. But then I saw that when I long press directly on the collection number in the Movies list, there is an option “Refresh”. If I choose this I get the collection title back. So with this I can fix the problem.
I just hope this doesn’t happen again. :grinning:
Just sent my diagnostics, code 4TRV2. I am on the latest official version, still got the problem, tried both refresh and clear Metadata.
Any news on this? Updated to latest official version and still got the same issue. Do I have to wait for the next official version? Thanks in advance!
Have you tried this?
Yup, no luck still…
It’d help to know the version number of Infuse you’re currently running since it’s updated frequently. :wink:
Maybe try turning off all the collection options in settings, then do a refresh from the Settings > Library page. After that go back to the collections options and turn on the ones you want.
It worked manually on latest stable version 7.4.3 I think. Will try and do what you said because there is no way to do manually allll my collections or I will scan my library from the beginning and let you know!
On latest version problem still remains. I tried the workaround you proposed but when I re-enable the collections options I get the numbers again…
Do newly created collections show names or numbers?
If the former, you just might need to start over?
