I was wondering if anyone knows how to have the movies listed in the movies section that are in Plex Collections. I want to both have the option of the Collection and have the movies listed separately.
Thanks!
Thanks!
Anyone?
Have you tried turning off collections in settings? Then your movies will be listed as individuals but still show the collections when you choose the “Collections” under movies in the library.
Put the Plex Library to favourites instead of using the Infuse Library.
Edit: Just checked the solution from NC Bullseye which also seems to work.
