Clear restore path...
Greetings - I have purchase the aTV and created my flash stick, however, I can’t seem to find information about restoring the Apple TV should I run into a problem. Is there a clear path to “restoring” the Apple TV to its factory settings if need be? I’m sure this topic has been addressed, I’m just having trouble locating it.
Thanks-
eric
If your AppleTV can boot into its interface then you can just go to Settings > Genreal > Reset Settings > Factory Restore. If you can not get into the interface of AppleTV, then you can hold the Menu and — keys on the Apple Remote for 5-10 seconds and it will reboot the AppleTV and after a minute or two you should see a screen where you can to a Restore, run diagnostics, or simply Restart. Those are the only methods I know of to Restore an AppleTV.
Awesome! Thanks for the info - off I go to install aTV!!!
eric
