We want to change genre’s artworks!!!
Here is one way to do that but takes a little work
You know that was even doable in V6? Just do a long press on the genre icon and choose select artwork.
All it shows is “Update Artwork”. No option for custom design.
Maybe you dont use Infuse or is being guided by missdirection but, UPDATE ARTWORK is not CUSTOM; we want to use CUSTOM ARTWORK on Genres.
OK, I see where you and I were looking at two different things. I had added the individual genres to the favorites and that way you can select what ever artwork you want but when you pin the entire “By Genre” to the home screen you get the pre=selected artwork.
Sorry for the misunderstanding.
