I try to change the pictures of the favorites but can’t get it to work (pic1) the orange ones is how it is want to change it but wil not workvia (pic 2). can somebody point me in de right directuin or tell me how to do it.
Thnx already
The normal condition is when you click select button, you will enter table of contents and select you like image from folder
I tried via the contens but ik won’t see the .jpg or do i have to give them an other name ?
if you use smb/webdav to connect and turn on library mode, you can put a image to classify catalogue and name folder.jpg, infuse will auto identify as cover
