Certain Artwork Not Displaying
I noticed that certain custom cover art isn’t displayed properly on my iOS device. The season art for Critical Role as well as Relics and Rarities isn’t the custom one I’ve uploaded.
Also, the Season specific Artwork isn’t displayed properly.
This is how I have them organioand labeled in folders.
It only seems to happen to these images and no other ones. I’ve deleted the cached metadata memory, refreshed the artwork, and tried renaming them with no success.
I would very much appreciate any help you can offer.
Many thanks!
Can you try removing the 0s from the season numbers (folders and images) to see if this helps? IIRC, these are pretty specific so as not to slow down browsing.
EG
Season 1
The complete list of usage guidelines for TV show artwork is copied below.
Episode poster
seriesname/season 1/episodefilename.jpg
Season poster
seriesname/season 1-poster.jpg
All Seasons poster
seriesname/season-all-poster.jpg
Series poster (available only while using Library)
seriesname/poster.png
Series fanart
seriesname/fanart.png
Hi James. I removed the 0s and it didn’t seem to work. I did however stumble on something though. I had some episodes downloaded and synced locally on my device and once I deleted those the cover art and everything went back to working normally.
Thank you for all your help. Infuse has definitely become my go-to media app and the continued support and updates are very much appreciated.
