Cataloguer infuse
Hello!
https://www.kinopoisk.ru/series/1224067/
infuse cannot identify the series. Whatever the files are called. Manual search also does not lead to a result. Is there any way to fix the situation?
How do you have the files named?
First, try this. “Вампиры средней полосы 2021 S01E01.mkv”
You could use “The Vampires of Midland 2021 S01E01.mkv” for the file name structure in English and it should also pick it up.
Ann additional note.
I just tested this format and it picked up the correct show right away.
Thanks! It worked.
